Das FujiNet NOS verfügt über XIO 39 und 40, die Binärdateien laden können. Es ist derselbe Lader, der in den Befehlsprozessor eingebaut ist, und kann Dateien von jedem Netzwerkendpunkt laden.
Wie wäre es, wenn ein Front-End für a8.fandal.cz oder homesoft erstellt wird, das durchsucht werden kann?
The FujiNet NOS has XIO 39 and 40, which can load binary files. It's the same loader that's built into the command processor, and can load files from any network endpoint.
How about a front-end is made for a8.fandal.cz or homesoft, that can be searched?
while I think it is a great idea to have access to an extensive collection ...
- the files on Fandal's site are provided in ZIP archives and hence cannot be started on the fly
- and even if that worked it might be desirable to ask for Fandal's permission, I guess he doesn't want to get sued for some original soft he might have collected there
Best, Erhard
o_O
I'm sorry, I just have to stop and pause at the .... yeah...
I suppose either:
(a) making a front-end to a8.fandal.cz, or
(b) unpacking the zip elsewhere and making a searchable front-end to it
is a step too far?
-Thom
Hello Thom
Would FujiNet be able do unzip it on the fly?
Sincerely
maybe Fandal would be willing to add a TNFS service to his site?
However there will still be zipped files.
And there is an advantage of the files being zipped: a damaged archive states an error when trying to be unpacked but data corruption in plain files will pass undetected and a single flipped bit may make a game unwinnable.
I know that such damage occurs rarely but it does occur.
This is why some companies like Veeam and HPE provide MD5 checksums for their files on their websites that enable the recipient to verify the file integrity after download.
Best, Erhard
FujiNet could do this, but there is no need to do this , in this case.
I'm honestly taken aback that the point is being missed so broadly.
-Thom
I am sorry but I do not unterstand this sentence correctly.
I had Google try translate it but the meaning is still not clear.
Are you disappointed that I pointed-out that Fandal's archive consists of zipped files so that they are not directly loadable ?
Kind regards,
No. I am proposing to get a small group together to work on a nice front-end program to load games from Homesoft's and Fandal's archives.
Luckily, in both cases, whole ZIP archives are provided and these can be unpacked and used on a server, with a suitable service which can search through them and return paths back to the FujiNet to load.
It's exceptionally frustrating sometimes, it's like I have to present an idea fully baked, in every single case, and I can't write everything.
-Thom
this is something I always wonder about.
You are doing so much work that I cannot imagine how you manage to do this.
Kind regards,
Atari 8-bit FujiNet Homesoft Launcher beginnt zu funktionieren.
Er spricht mit einem in C geschriebenen Mikrodienst, sendet ihm die Abfrage und erhält einen Dump des Bildschirmspeichers mit den Ergebnissen zurück, der einfach direkt in den Bildschirmspeicher geladen wird.
Ich versuche wirklich, genug zum Laufen zu bringen, damit ich den #@$()@($-Punkt beweisen kann 🙂
Atari 8-bit FujiNet Homesoft Launcher starting to work.
It talks to a micro-service written in C, sends it the query, and gets back a dump of screen memory with the results, which just gets bulk-loaded right into screen memory.
I'm really trying to get enough working so I can prove the #@$()@($ point 🙂
WIP: A Search Tool for #Atari8bit #FujiNet users that searches the Homesoft Collection. You can pick a game, and launch it.
2025-02-18 14-00-51.mp4
this is looking great 🙂
